Username
  Password
site map
    About Hot-Dip Galvanizing
        Batch Galvanizing vs. Continuous Sheet Galvanizing
        Hot-Dip Galvanizing - facts about galvanized steel and corrosion prevention
        Facts About Zinc
        Frequently Asked Questions - galvanized steel, corrosion, zinc, etc.
        Glossary of Hot-Dip Galvanizing & Galvanized Steel Terms
        History of Hot-Dip Galvanizing
        Hot-Dip Galvanizing Process - animation and information
        Hot-Dip Galvanizing Industry Statistics
        Service Life Chart for Hot-Dip Galvanized Coatings
        Sustainable Development and Hot-Dip Galvanizing
    Technical Information on Hot-Dip Galvanizing
        Hot-Dip Galvanizing Animations
        Dr. Galv Technical Resource
        The Cost of Corrosion and the Application of Corrosion Resistant Materials
            The Corrosion Process and Hot-Dip Galvanizing for Protection
            Corrosion Data for Zinc with Chemicals, Soaps, and Synthetic Detergents
        Galvanize It! Seminar on Hot-Dip Galvanizing After Fabrication
            Online Seminar
        Designing with Hot-Dip Galvanized Steel - Fabricator Version CD-ROM
            Fabrication Considerations Prior to Hot-Dip Galvanizing Steel
                Abrasive Blasting for Cleaning Steel
                Bend Diameters for Steel to be Hot-Dip Galvanized
                Cold Worked Steel: The Effects of Strain-Age Embrittlement
                Galvanizing Dissimilar Steels - Protection is not Lost
                Stress Relieving in the Galvanizing Kettle: Distortion & Warping
                Considerations for Hole Sizes in Fabrications to be Galvanized
                Temporary & Permanent Identification Techniques on Galvanized Steel
                Masking to Allow for Intentionally Ungalvanized Areas
                Proper Material Handling for Quality in the Galvanizing Facility
                Hot-Dip Galvanizing Moving Parts
                Overlapping & Contacting Surfaces to be Galvanized
                Common Residues Found on Steel Prior to Galvanizing
                The Types of Steel Being Galvanized Influences the Coating's Appearance
                Size Considerations for Structural Fabrications to be Galvanized
                Steel Surface Considerations Before Hot-Dip Galvanizing
                Temporary Bracing for Control of Warping and Distortion
                Galvanizing Threaded Assemblies - Nuts & Bolts
                Venting & Drainage Considerations for Steel to be Galvanized
                    Venting & Drainage for Steel to be Galvanized - Tubular Fabrications
                    Venting & Drainage for Steel to be Galvanized - Handrails
                    Venting & Drainage for Steel to be Galvanized - Rectangular Tube Truss
                    Venting & Drainage for Steel to be Galvanized - Pipe Truss
                    Venting & Drainage for Steel to be Galvanized - Pipe Columns
                    Venting & Drainage for Steel to be Galvanized - Box Sections
                    Venting & Drainage for Steel to be Galvanized - Tapered Single Arm
                    Venting & Drainage for Steel to be Galvanized - Enclosed & Semi-enclosed
                    Venting & Drainage for Steel to be Galvanized - Drainage
                Increased Weight of Galvanized Steel
                Welding Steel Before Hot-Dip Galvanizing
            Fabrication Considerations after Hot-Dip Galvanizing
                Bending Hot-Dip Galvanized Steel
                Corrosion Performance
                Dissimilar Metals
                Dulling Surfaces
                Connections using Hot-Dip Galvanized Bolts
                Inspection
                Preparing Galvanized Surfaces for Painting
                Passivation
                Plugging Holes
                Repairing Bare or Damaged Areas
                Wet Storage Stain and Storage of Galvanized Steel
                Tapping Threads
                Welding after Galvanizing
        Hot-Dip Galvanized Steel + Paint
        List of Inspectors
        Literature & Publications - galvanized steel, hot dip galvanizing, painting
            Hot-Dip Galvanizing Costs Less and Lasts Longer
            Designing with Hot-Dip Galvanized Steel - CD-ROMS
            Hot-Dip Galvanized Fasteners and Structural Joints
            Directory of North American Galvanizers
            History and Development of the Galvanizing Industry
            Hot-Dip Galvanizing Inspections and Touch-ups
            Duplex Systems - Painting Over Hot-Dip Galvanized Steel
            Galvanized Steel Application and Performance Reports
                Agriculture and Food Processing Project Reports
                Bridges and Public Transportation Project Reports
                Building Structures Project Reports
                Chemical and Petrochemical Project Reports
                Miscellaneous Project Reports
                Power Generation and Distribution Project Reports
                Pulp and Paper Project Reports
            Galvanized Reinforcing Steel - Hot-dip Galvanizing Rebar for Corrosion Prot
            Specifying Hot-Dip Galvanizing
            Welding and Hot-Dip Galvanized Steel
            wet storage stain, white rust and hot-dip galvanized steel
            Zinc Coatings - Paint, Metallizing, Electrogalvanizing, Plating, Hot-Dip Ga
            AGA Publication Order Form
            Members Only Publications and Resources
        Galvanizing Industry-related Articles Published By AGA Staff Members
        Designing with Hot-Dip Galvanized Steel - Specifier Version CD-ROM
            The Corrosion Performance of Galvanized Steel
                How Does Zinc Protect Steel From Corrosion?
                The Development of a Natural Protective Patina
                The Corrosion Performance of Galvanized Steel in Atmospheric Conditions
                The Performance of Galvanize Steel in Chemical Environments
                corrosion Performance of Galvanized Steel in a Water Environment
                Corrosion Performance of Galvanized Steel in Soil
                Corrosion Performance of Galvanized Steel in Concrete
                Concrete Corrosion References
                Corrosion Properties of Dissimilar Metals in Contact with Galvanized Steel
                The Correct Test Method to Determine a Proper
                Various Data on Corrosion
            The Economics of Hot-dip Galvanized Steel
                Economic Analysis of Original and Life-cycle Costs of DHG Steel and Paint
                Hot-dip Galvanizing Case Studies
                A Cost Comparison of Hot-dip Galvanized Steel and Paint
            The Hot-dip Galvanized Coating Structure
                Physical Properties that Impact the Appearnace and Use of Galvanized Steel
                The Characteristics of Zinc That Make it Well Suited as a Protective Coatin
                Duplex Systems - Applying Paint and/pr Powder Coatings Over Hot-dip Galvani
                Painting Hot-dip Galvanized Steel
                Powder Coatings on Hot-dip Galvanized Steel
            Specifications Relating to the Hot-Dip Galvanizing Process
            American Society for Testing and Materials (ASTM) Relating to Hot-Dip Galva
            The Facts About Galvanizing and Sustainable Development
                Zinc and the Environment
                The Benefits of Zinc and Livnig Organisms
                The Recycling of Zinc
            Particular Properties of Zinc Metal
                The Physical and Mechanical Properties of Zinc Metal
                The Thermal Properties of Zinc Metal
                The Electrical Properties of Zinc Metal
                Other Uses of Zinc Metal
        Galvanizing Insights - Specifier Newsletter for the Galvanizing Industry
            Galvanizing Insights - Archives 1996-2002
                Galvanizing Insights 1996
                Galvanizing Insights 1997
                Galvanizing Insights 1998
                Galvanizing Insights 1999
                Galvanizing Insights 2000
                Galvanizing Insights 2001
                Galvanizing Insights 2002
                Galvanizing Insights, 2003
                Galvanizing Insights, 2004
        TechForum 2008 - Fort Worth, TX - Galvanizing Technical Conference
            TechForum 2007 Call for Papers
    Galvanized Steel in Use - hot dip galvanized steel in the field
        AGA Excellence Awards - hot dip galvanizing at its finest
        Galvanizing Projects - searchable case studies, performance reports, pictur
        Hot-Dip Galvanized Steel vs. Epoxy-Coated Rebar
        Hot-Dip Galvanized Steel vs. Paint
        Hot-Dip Galvanized Steel vs. Weathering Steel
        HDG vs. zinc-rich paint
        zinc coating life predictor
    About AGA - American Galvanizers Association
        contact us
        mission statement
        AGA Staff
        membership information
            member benefits
            membership categories
            membership application
            member support services
            member committees
        calendar/events
        news
        AGA Sustainable Development Charter
        Galvanize the Future Scholarship Essay Contest
    members only
        Administrative Department
            Annual Report
            Human Resource Guide for Hispanic Employees
            AGA Membership Advantages
        Marketing Department Activities
            Marketing Department Focus Groups
            The Galvanize It! Seminar
            Regional Member Marketing Committees
            Winning Scholarship Essays
            2006 Specifier Survey Complete Analysis
            ThinkZinc 2008
            AGA Exhibited Tradeshows
        Technical Department Activities
            Environmental, Health, & Safety Notes
            Galvanizing Guidelines
            Galvanizing Notes
            HDG Steel Data Sheet
            Galvanizing Process Seminars
            Technical Research Library Index
            Member Only Technical Research & Information
            TSC Subcommittees
            Member Only White Papers
        2009 Annual Conference
        American Galvanizer Newsletter
            2007 American Galvanizer Newsletter
            2006 American Galvanizer Newsletter
            2005 American Galvanizer Newsletter
            2004 American Galvanizer Newsletter
            2003 American Galvanizer Newsletter
        calendar/events
        member directory
            galvanizers
            galvanizers M-Z
            sustaining
            Associate Members of the American Galvanizers Association
            Other Organizations
            Foreign Galvanizer Associations
            bylaws
        AC Downloads
