Highlighted Publications can be downloaded for FREE using Adobe Acrobat Reader
Online Publication Order Form
Hot Dip Galvanizing for Corrosion Prevention: A guide to specifying and inspecting hot-dip galvanized reinforcing steel (2004) After a brief look at corrosion and the hot-dip galvanizing process, hot-dip galvanized rebar's performance in concrete, design, specification, fabrication, and installation issues are addressed. 16 pages, SP-SGRS-04 $3.80
Hot-Dip Galvanized Rebar vs. Epoxy-Coated Rebar (2006) The newest handout in the series compares hot-dip galvanized rebar with epoxy-coated rebar. This comprehensive 4-page brochure features a side-by-side comparison of performance, a detailed account of concrete corrosion, HDG rebar bridge case studies, and a history of the HDG rebar in use. C-GvsECR-06 $1.13
Hot-Dip Galvanized Reinforcing Steel: A Concrete Investment (2006) This publication by the International Zinc Association is a comprehensive resource of the performance of hot-dip galvanized rebar in concrete. Several project examples from around the world highlight the brochure. This publications was also designed in conjunction with http://www.galvanizedrebar.com. For Download Only
No Preview Available |
Field Handling Guide: HDG vs. Fusion-Bonded Epoxy Rebar (2000) This convenient field handling guide compares and contrasts hot-dip galvanized rebar with fusion-bonded epoxy rebar. It discusses areas such as: storage, placement, field cutting, final inspection, and much more. RE-FH-00 $1.12 |
