Username
  Password
design CDs
excellence awards
galvanizing projects
HDG vs. epoxy
HDG vs. paint
HDG vs. weathering Steel
HDG vs. zinc-rich paint
zinc coating life predictor
galvanized steel in use:  HDG vs. paint
HDG vs. Paint
Hot-Dip Galvanizing vs. Paint Cost Comparison
Using data collected in nationwide surveys of the hot-dip galvanizing industry (conducted by the American Galvanizers Association) and the paint industry (conducted by the National Association of Corrosion Engineers), an economic analysis of original and life-cycle costs provides an interesting comparison.
Original Costs
Although not recommended as reflecting the true cost of a corrosion protection system, original costs are sometimes the primary determinant for selection. Hot-dip galvanizing is more economical from an initial cost standpoint for all but the one-coat zinc-rich paint and the two-coat acrylic waterborne paint. This is the case when galvanizing is compared to many of the commonly used industrial paint systems. Additionally, hot-dip galvanizing may be even more economical when the project calls for small-weight-per-beam-length structural steel and/or assemblies, because of the efficient handling of many pieces in the galvanizing process.
Life-cycle Costs
Because of the long life of the hot-dip galvanized coating and its virtually maintenance-free performance, galvanizing is consistently a better value than paint over a structure's life. Galvanizing durability and lifetime performance make it the logical choice when it is the lowest original cost system.
The UK Galvanizers Association published a technical update of a study commissioned by IZA that compares the performance of hot-dip galvanized steel with paint. The study examined a balcony application and compares total life cycle energy, environmental impacts, and life cycle inventory of galvanized steel to paint.
View the article.
Would you like to see an animation about Hot-Dip Galvanizing vs. Paint?
Click here to view it in Flash
