Username
  Password
animations
ask Dr. Galv
corrosion
educational seminars
fabricator CD
HDG + Paint
inspectors
literature
published articles
specifier CD
  -corrosion performance
  -cost/economics
  -the HDG coating
  -related specifications
  -ASTM standards
  -sustainable development
  -zinc metal facts
specifier newsletter
techforum
technical info:  specifier CD:  ASTM standards
ASTM STANDARDS RELATING TO HOT-DIP GALVANIZING AND
HOT-DIP GALVANIZED MATERIALS
A 36 Specification for Structural Steel
A 123 / A 123 M Specification For Zinc (Hot-Dip Galvanized) Coatings On Iron And Steel Products
A 143 Practice For Safeguarding Against Embrittlement Of Hot-Dip Galvanized Structural Steel Products And Procedure For Detecting Embrittlement
A 153 / A 153 M Specification For Zinc Coating (Hot-Dip) On Iron And Steel Hardware
A 384 Practice For Safeguarding Against Warpage And Distortion During Hot-Dip Galvanizing Of Steel Assemblies
A 385 Practice For Providing High-Quality Zinc Coatings (Hot-Dip)
A 500 Specification for Cold-Formed Welded and Seamless Carbon Steel Structural Tubing in Rounds and Shapes
A 501 Specification for Hot-Formed Welded and Seamless Carbon Steel Structural Tubing
A 563 Standard Specification for Carbon and Alloy Steel Nuts
A 572 Specification for High-Strength Low-Alloy Columbium-Vanadium Steels of Structural Quality
A 767 / A 767 M Specification For Zinc-Coated (Galvanized) Steel Bars For Concrete Reinforcement
A 780 Practice For Repair Of Damaged And Uncoated Areas Of Hot-Dip Galvanized Coatings
A992 Specifications for Steel Structural Shapes For Use in Building Framing
B 6 Specification For Zinc
D 6386 Practice For Preparation Of Zinc (Hot-Dip Galvanized) Coated Iron And Steel Products And Hardware Surfaces For Painting
E 376 Practice For Measuring Coating Thickness By Magnetic-Field Or Eddy-Current (Electromagnetic) Test Methods
ASTM's copyright does not allow us to include full-text versions of the above-listed specifications in this program. However, a compilation of all specifications is available to order from the American Galvanizers Association. Call 800-468-7732 or e-mail aga@galvanizeit.org.
CANADIAN STANDARDS ASSOCIATION
G40.8* Structural Steel with Improved Resistance to Brittle Fracture
G40.12* General Purpose Structural Steel
G164 Galvanizing of Irregularly Shaped Articles
* Superseded by G40.20/G40.21 General Requirements for Rolled or Welded Structural Quality Steel
^ back to top
