Username
  Password
animations
ask Dr. Galv
corrosion
educational seminars
fabricator CD
  -pre-fab considerations
  -post-fab considerations
HDG + Paint
inspectors
literature
published articles
specifier CD
specifier newsletter
techforum
technical info:  fabricator CD:  post-fab considerations:  storage
Storing Galvanized Steel
Hot-dip galvanized coatings protect steel by providing both cathodic and barrier protection. The naturally occurring formation of a tenacious, abrasion-resistant zinc carbonate patina provides yet another component to the protection afforded by galvanizing. The formation of this patina depends on the galvanized steel's being exposed to freely circulating air.
Stacking galvanized articles closely together for extended periods of time, thereby limiting access to freely circulating air, can lead to the formation of a white powdery product commonly called "wet storage stain."
Fabricated assemblies that fully expose the galvanized surfaces to freely circulating air typically do not need a post-treatment to prevent the formation of wet storage stain. Although most after-fabrication hot-dip galvanized products are shipped without any post-treatment, the need for a post-treatment largely depends on the fabrication's configuration and anticipated storage and shipping conditions.
The extent of damage by wet storage stain depends on the duration of exposure to the wet-storage-stain-inducing environment and retained moisture. The attack is accelerated when the retained moisture contains chlorides from seawater, sulfur compounds from industrial environments, or flux residues from galvanizing operations.
To minimize the possibility of wet storage stain, consider these guidelines:
  • provide adequate ventilation between stacked pieces and avoid nested stacking,
  • elevate and separate articles stacked outdoors with strip spacers (poplar, ash, spruce); also use spacers during shipping if there is the likelihood of condensation,
  • incline parts to allow for maximum drainage,
  • prevent uncovered material from being left at in-transit loading points where it may be exposed to rain, mist, condensation, or snow,
  • thoroughly dry small items that are quenched and stored in containers and include a dehumidifying agent in the sealed containers,
  • store galvanized material under cover in dry, well-ventilated conditions, away from doorways open to the environment,
  • treat with a passivating agent, and/or
  • maintain a low humidity environment around the material.
Would you like to see an animation about Preventing Wet Storage Stain?
Click here to view the Flash Animation
It will take 20 - 200 seconds to load depending on your connection.
Wet storage staining is often superficial, despite the possible presence of a bulky, white product. In the vast majority of cases, wet storage stain does not indicate serious degradation of the zinc coating, nor does it necessarily imply any likely reduction in the product's expected service-life.
Various surface treatments are available to reduce the possibility of wet storage stain, including
  • waxes and oils for products such as wire, sheet steel and fencing, and
  • passivation treatments for structural fabrications, conduit and hollowware.
If wet storage stain does form, the objects should be arranged so that their surfaces dry rapidly. Once dry, most stains can be easily removed by brushing with a stiff bristle (not wire) brush. If the affected area will not be fully exposed in service or if it will be subject to an extremely humid environment, even superficial white films should be removed with a soft-bristle brush. This allows for the successful formation of galvanized coatings' protective zinc carbonate patina.
In cases where heavy white deposit or red stain has formed because of prolonged exposure to or storage under poor conditions, it must be removed and the damaged area repaired as detailed in ASTM A 780. In advanced stages of wet storage stain, the typical white or gray product may blacken. When this occurs, some of the protective coating has been consumed, affecting service-life.
Coating thickness tests can be performed on affected areas to ensure that sufficient zinc coating remains after the removal of the wet storage stain. Where the surface staining is light and smooth -as judged by lightly rubbing fingertips across the surface -the stain will disappear gradually and blend with the surrounding surface during normal weathering.
