Username
  Password
animations
ask Dr. Galv
corrosion
educational seminars
fabricator CD
  -pre-fab considerations
  -post-fab considerations
HDG + Paint
inspectors
literature
published articles
specifier CD
specifier newsletter
techforum
technical info:  fabricator CD:  pre-fab considerations:  masking
Masking to Allow for Intentionally Ungalvanized Areas
During the galvanizing processes, all surfaces are cleaned and coated with corrosion-inhibiting zinc. For some purposes, intentionally ungalvanized areas are required. Masking may be performed to accomplish this.
Masking is treating a portion of the steel surface so the area remains ungalvanized. Masking is not an exact science; additional work may still be required to remove unwanted zinc.
Would you like to see an animation about Masking of a Part?
Click here to view it in Flash
It will take 20 - 200 seconds to load depending on your connection.
In most cases, it may be easier to grind off the zinc coating after galvanizing than to mask the material.
There are four major categories of masking materials:
  • acid-resistant, high-temperature tapes,
  • water-based pastes and paint-on formulations,
  • resin-based, high-temperature paints, and
  • high-temperature greases and thread compounds.
Consult with your galvanizer to arrive at the best solution for any particular design.
