Username
  Password
animations
ask Dr. Galv
corrosion
educational seminars
fabricator CD
  -pre-fab considerations
  -post-fab considerations
HDG + Paint
inspectors
literature
published articles
specifier CD
specifier newsletter
techforum
technical info:  fabricator CD:  pre-fab considerations:
Hot-dip galvanizing steel fabrications is the most effective, cost-efficient method for providing an extended service life. To get a clear understanding of how materials are handled at the galvanizing facility, view the animation below. As straightforward as the galvanizing process is, time and money are saved when pre-fabrication design considerations are factored into the project at its earliest stages.
Select a topic from the list below to view detailed information on each subject:
Would you like to view the Process Animation?
Click here to view it in Flash
It will take 20 - 200 seconds to load depending on your connection.
