The specification ASTM A 153/A 153M applies to hardware products such as castings, fasteners, rolled, pressed and forged products, and miscellaneous threaded objects that will be centrifuged, spun, or otherwise handled to remove the zinc, as seen in Figure 12.
Figure 12: Galvanized Fasteners
The requirements for ASTM A 153/A 153M are very similar to those reported earlier for ASTM A 123/A 123M, except for the addition of threaded products and embrittlement requirements.
ASTM A 153/A 153M Requirements
  • Coating Thickness/Weight – depends on the material category and steel thickness, values are listed in Table 3
  • Threaded Products – areas with threads are not subject to the coating thickness requirement
  • Finish – continuous, smooth, uniform
  • Embrittlement – high tensile strength fasteners (>150ksi) and castings can be subject to embrittlement
  • Appearance – free from uncoated areas, blisters, flux deposits and gross dross inclusions as well as having no heavy zinc deposits that interfere with intended use
  • Adherence – the entire coating should have a strong adherence throughout the service life of hot-dip galvanized steel
There are fabrication steps that may impair the corrosion protection of the hot-dip galvanized coating, however, flaking or damage to the coating because of this is not case for rejection. In all cases, good steel selection results in the formation of a higher quality coating and finish on the product. The corrosion protection coating for threaded products is applied after the product has been fabricated and further fabrication may compromise the corrosion protection system. The one exception to this rule is the internal threads of a nut that should be over-tapped after the coating is applied in order to accommodate the coating thickness change on the thread of the bolts. In this case, the zinc on the bolt threads provides the corrosion protection to the uncoated threads in the nut.
There are certain fabrication techniques that can induce stresses into the steel and lead to brittle failure. There are precautions given in ASTM A 143/A 143M that should be taken in order to prevent embrittlement. In addition, selecting steels with appropriate chemistries can help prevent embrittlement of malleable castings. A reproduction and summary of the table given in ASTM A 153/A 153M, which is seen in Table 3, gives the different classes of products and the minimum coating thickness required by the specification.
Table 3: Minimum Average Coating Thickness by Material Class (From ASTM A 153)
Prev | Next
