Figure 46: Weeping Weld
Weeping Weld
Weeping welds stain the zinc surface at the welded connections on the steel. They are caused by entrapped cleaning solutions that penetrate the incomplete weld. In order to avoid weeping welds for small overlapping surfaces, completely seal weld the edges of the overlapping area. For larger overlapping areas, the area cannot be seal welded since the volume expansion of air in the trapped area can cause explosions in the galvanizing kettle. To avoid weeping welds in large overlapping areas, the best plan is to provide a 3/32” (2.4mm) or larger gap between the two pieces when welding them and let the zinc fill the gap between the pieces. This will actually make a stronger joint when the process is complete. Weeping welds, as seen in Figure 46, are not the responsibility of the galvanizer and are not cause for rejection.
Figure 47: Welding Blowouts
Welding Blowouts
Welding blowout is a bare spot around a weld or overlapping surface hole. These are caused by pre-treatment liquids penetrating the sealed and overlapped areas that boil out during immersion in the liquid zinc. This causes localized surface contamination and prevents the galvanized coating from forming. In order to avoid welding blowouts, as seen in Figure 47, check weld areas for complete welds to insure there is no fluid penetration. In addition, products can be preheated prior to immersion into the galvanizing kettle in order to dry out overlap areas as much as possible. Welding blowouts cause bare areas that must be repaired before the part is acceptable.
Figure 48: Welding Spatter
Welding Spatter
Welding spatter appears as lumps in the galvanized coating adjacent to weld areas. It is created when welding spatter is left on the surface of the part before it is hot-dip galvanized. In order to avoid welding spatter, welding residues should be removed prior to hot-dip galvanizing. Welding spatter, as seen in Figure 48, appears to be covered by the zinc coating, but the coating does not adhere well and can be easily removed. This type of defect can leave an uncoated area or bare spot if the zinc coating is damaged and must be cleaned and properly repaired.
Wet Storage Stain
Wet storage stain is a white, powdery surface deposit on freshly galvanized surfaces. It is caused by newly galvanized surfaces being exposed to fresh water, such as rain, dew, or condensation that react with the zinc metal on the surface to form zinc oxide and zinc hydroxide. It is found most often on tightly stacked and bundled items, such as galvanized sheets, plates, angles, bars, and pipes. Wet storage stain can have the appearance of light, medium, or heavy white powder on the galvanized steel product. Each of these appearances can be seen from right to left in Figure 49.
One method to avoid wet storage stains is to passivate the product after galvanizing by using a chromate quench solution. Another precaution is to avoid stacking products in poorly ventilated, damp conditions. Light or medium wet storage stain will weather over time in service and is acceptable. In most cases, wet storage stain does not indicate serious degradation of the zinc coating, nor does it necessarily imply any likely reduction in the expected life of the product. However, heavy wet storage stain should be removed mechanically or with appropriate chemical treatments before the galvanized part is put into service. Heavy storage stain must be removed or the part must be rejected and regalvanized.
Figure 49: Wet Storage Stain
Figure 50: Zinc Skimming Inclusions
Zinc Skimmings
Skimming deposits are usually caused when there is no access to remove the skimmings during the withdrawal of the steel from the galvanizing kettle. The skimmings on the liquid zinc surface are trapped on the zinc coating. In order to remove zinc skimmings without harming the soft zinc coating underneath, lightly brush them off the surface of the galvanized steel during the in-house inspection stage with a nylon-bristle brush. Zinc skimmings, as seen in Figure 50, are not grounds for rejection. The zinc coating underneath is not harmed during their removal and it meets the necessary specifications.
Figure 51: Zinc Splatter
Zinc Splatter
Zinc splatter is defined as splashes and flakes of zinc that loosely adhere to the galvanized coating surface. Zinc splatter is created when moisture on the surface of the galvanizing kettle causes liquid zinc to “pop” and splash droplets onto the product. These splashes create flakes of zinc loosely adherent to the galvanized surface. Zinc splatter, as seen in Figure 51, will not affect the corrosion performance of the zinc coating and is not cause for rejection. The splatter does not need to be cleaned off the zinc coating surface, but can be if a consistent, smooth coating is required.
Prev | Next
