Masking to Allow for Intentionally Ungalvanized Areas
During the galvanizing processes, all surfaces are cleaned and coated with corrosion-inhibiting zinc. For some purposes, intentionally ungalvanized areas are required. Masking may be performed to accomplish this.
Masking is treating a portion of the steel surface so the area remains ungalvanized. Masking is not an exact science; additional work may still be required to remove unwanted zinc.
In most cases, it may be easier to grind off the zinc coating after galvanizing than to mask the material.
There are four major categories of masking materials:
- Acid-resistant, high-temperature tapes
- Water-based pastes and paint-on formulations
- Resin-based, high-temperature paints
- High-temperature greases and thread compounds
In addition to these designated masking materials, the American Galvanizers Association recently conducted a study evaluating the effectiveness of common commercial products in masking the surface. The results of that study can be found in the Galvanizing Note Masking Materials for Preventing Hot-Dip Galvanizing.
If you plan to apply a masking material, consult with your galvanizer to arrive at the best solution for any particular design and be sure to notify him of any areas purposely masked to avoid inadvertent removal of the masking compound.
