Physical and Mechanical Properties
Tensile Strength
   (cast) 28 MN/m2 (4,000 psi)
   (rolled, with grain)
   (99.95% zinc soft temper) 126 MN/m2 (18,000 psi)
   (98.0% zinc hard temper) 246 MN/m2 (35,000 psi)
Elongation (rolled, with grain)
   (99.95% zinc soft temper) 65%
   (98.0% zinc hard temper) 5%
Modulus of elasticity 7 x 104 MN/m2 (1 x 107 psi)
Brinell hardness, 500 kg load for 30 sec. 30
Impact resistance
   (pressed zinc, elongation = 30%) 6.5-9 J/cm2 (26-35 ft-lbs/in2)
Surface tension, liquid (4500C) 0.755 N/m
Surface tension, liquid (419.50C) 0.782 N/m
Viscosity, liquid (419.50C) 0.00385 N/m
Coefficient of friction (rolled zinc vs rolled zinc) 0.21
Density See chart below
Hardness 2.5 mohs
Surface Reflectivity See chart below
Density
Reflectivity
Back to Top
Thermal Properties
Melting point 419.50C (787.10F)
Boiling point (760 mm Hg) 9070C (1664.60F)
Combustion temperature 18000C (approx, 32720F)
Vapor pressure (419.50C) 1.39 x 10-1 mm Hg
Thermal Conductivity
     solid (180C) 113 W/m.K
     solid (410.50C) 96 W/m.K
     liquid (419.50C) 164 W/m.K
     liquid (7500C) 57 W/m.K
Linear coefficient of thermal expansion
    (single crystal along a axis 0-1000C) 15 mm/ m.K
    (single crystal along c axis 0-1000C) 61 mm/ m.K
    (polycrystalline 20-2500C) 39.7 mm/ m.K
Volume coefficient of thermal expansion
     (20-4000C) 0.89 x 10-6/K
     (120-3600C) 0.85 x 10-6/K
Contraction on freezing at 419.50C 4.48%
Volume change on freezing 460 C -> 00C 7.28%
Specific heat (200C) 0.382 kJ/kg.K
Latent heat of fusion (419.50C) 100.9 kJ/kg
Latent heat of vaporization (9060C) 1.782 MJ/kg
Heat capacity
     solid Cp = 22.40 +10.5 x 10-3 Tjmol-1 (298-692.7 K)
     liquid Cp = 31.40 Jmol-1
     gas Cp = 20.80 Jmol-1
Back to Top
Electrical, Magnetic and Electrochemical Properties
Electrical Resistivity
   (polycrystalline at 200C) 5.9 mWm
   (liquid at 419.50C) 37.4 mW1m
   (single crystal along a axis at 200C) 5.83 mWm
   (single crystal along c axis at 200C) 6.16 mWm
Temperature coefficient of electrical resistivity
   (between 0 and 1000C) 0.0419 nWm/K
   (between 170 and 250C) 0.0406 nWm/K
Pressure coefficient at 200C
      (at 100 kPa-300 kPa) 25 nWm per Tpa
Superconductive at 0.84 ￯﾿ツ￯ᄒᄆ 0.05 K
Magnetic susceptibility
   (polycrystalline at 200C) -0.123 x 10-6 mks
   (single crystal along a axis at 200C) -0.169 x 10-6 mks
   (single crystal along c axis at 200C) -0.124 x 10-6 mks
Electrochemical properties
Standard electrode potential
   (against H2 electrode) -0.762 V
   (hydrogen overvoltage) 0.75 V at 108 A/m2 for metal rubbed with fine emery
Temperature coefficient of overvoltage -0.002 V/0C
Electrochemical equivalent 338.8 mg/0C   1.2195 kg/1,000 amp hr
Back to Top
Other Uses of Zinc
Zinc First Uses
Zinc End Uses
Zinc Geographic Consumption
Back to Top
