AGA | American Galvanizers Association
  • Home
  • Find a Galvanizer
  • AGA Publications
  • Member Login
Want Design Inspiration?
Browse...
  • Galvanized Projects
  • 2011 Award Winners
  • Duplex Systems
Need Continuing Education Credits?
Learn More...
  • In-Person Seminar
  • Online Seminar
  • Webinar Series
Site Map »
Site Search
  • About Hot-Dip Galvanizing & Corrosion Protection
  • Designing & Fabricating for Hot-Dip Galvanizing
  • specifying & Inspecting Galvanized Steel
  • Galvanized Steel in use
  • Education & Resources
  • About AGA
  • Design Considerations
    • Bend Diameters
    • Cold Worked Steels
    • Dissimilar Steel Chemistries
    • Dissimilar Metals in Contact
    • Distortion & Warping
    • Fasteners, Bolts & Nails
    • Part Identification
    • Masking
    • Material Handling
    • Moving Parts
    • Overlapped Surfaces
    • Steel Residues
    • Steel Selection
    • Steel Size Limits
    • Steel Surfaces
    • Temporary Bracing
    • Venting & Drainage
      • Tubular Fabrications
      • Handrail
      • Rectangular Tube Truss
      • Pipe Truss 3" (8cm) & Larger
      • Pipe Columns, Girders & Poles
      • Box Sections
      • Tapered – Single Arm
      • Enclosed & Semi-Enclosed Products
      • Drainage
    • Weight Increase
    • Welding Before HDG
    • Zinc Metal Properties
  • Fabrication Considerations
Home »
Page Not Found
We’re sorry, but the page or file you requested is not available.
You may find what you are looking for by using our site search (top right corner of this page) or by browsing the site map.
© 2012 American Galvanizers Association.
Contact Us | Site Map Terms of Use | Privacy Policy | Knowledgebase | Galvanizing Cost Calculator
