Best design practice for corrosion protection suggests to avoid dissimilar metals in contact whenever possible. Zinc, used to coat hot-dip galvanized fasteners, sacrifices itself to protect nearly every other metal, diminishing its longevity. Therefore, to enhance corrosion protection, hot-dip galvanized fasteners are recommended for galvanized structural assemblies.
Best practice also recommends studs and bolted assemblies be sent to the galvanizer disassembled. Furthermore, low carbon and low silicon bars are recommended as the fastener material to be galvanized since high carbon and silicon levels cause heavier, rougher galvanized coatings.
On threaded assemblies with diameters greater than 1.5 inches (1.8 cm), it is often more practical, if design strength allows, to have the male thread cut 0.031” (0.8 mm) undersize before galvanizing so a standard tap can be used on the nut.
Sharp manufacturing tools should be used to minimize the possibility of ragged and torn threads opening up during the cleaning phase of the galvanizing process. Standard-sized threads are cut on the bolt, while standard-sized nuts are re-tapped oversize after galvanizing to allow for the dimensional increase in the threads from the zinc coating.
Overtapping Guidelines for Nuts and Interior Threads
Nominal Nut Size (inches)
and Pitch
Diametrical Allowance
(inches)
0.250-20 0.016
0.312-18 0.017
0.375-16 0.017
0.437-140.018
0.500-13 0.018
0.562-12 0.020
0.625-11 0.020
0.750-10 0.022
0.875-9 0.022
1.000-8 0.024
1.125-8 0.024
1.125-7 0.024
1.250-8 0.024
1.250-7 0.024
1.375-8 0.027
1.375-6 0.027
1.500-8 0.027
1.500-60.027
1.750-5 0.050
2.000-4.5 0.050
2.250-4.5 0.050
2.500-4.5 0.050
2.750-4 0.050
3.000-4 0.050
3.250-40.050
3.500-4 0.050
3.750-4 0.050
3.750-4 0.050
4.000-4 0.050
For metric overtapping allowances, see ASTM A 563M, section 7.
